Cables
Latest about Cables
![Red and black terminated speaker cable on a white background](https://cdn.mos.cms.futurecdn.net/5TsEXQEYLns26AP3FnLaHJ-320-80.jpg)
Best speaker cables 2025: our editors' choice for every budget
By Becky Roberts last updated
Best Buys Don't let the humble looks fool you – speaker cables are one of the heroes of your hi-fi system and could be the most cost-effective upgrade you'll ever make.
![Audio cable: Chord Company ClearwayX ARAY Analogue RCA](https://cdn.mos.cms.futurecdn.net/JS37sj6DjgsCm8m3A83FSJ-320-80.jpg)
Best audio cables 2025: our expert picks of quality interconnects
Best buys Upping your audio cable game is a simple yet very effective way to give your hi-fi system a boost. Here are our favourites...
By What Hi-Fi? last updated
Updated If you’re looking at ways to eke out the best performance from your hi-fi system, this audio interconnect cable offers a significant uplift
![Chord Company C-line cable on a white background](https://cdn.mos.cms.futurecdn.net/JGeCBrNmb7Zvbh88ViEnNm-320-80.jpg)
Updated This Chord interconnect is a no-brainer if you want to give your hi-fi system a lift....
![Speaker cable: Chord Company RumourX (2022)](https://cdn.mos.cms.futurecdn.net/7yetGaqM2ZH292Yn4huLuR-320-80.jpg)
Updated An improved plating on the banana plugs makes the award-winning Chord Company RumourX an even better buy.
![Ecosse CS2.15Mk2 speaker cable on white surface](https://cdn.mos.cms.futurecdn.net/ebG9zDX2SKaQNcoUTbNsh4-320-80.jpg)
Ecosse CS2.15Mk2
By What Hi-Fi? published
The CS2.15 Mk2 delivers a cohesive and detailed performance to make it worthy of consideration.
![The connections at the rear of a soundbar, including three HDMI sockets, one of which is labelled 'TV ARC'](https://cdn.mos.cms.futurecdn.net/QXbvqumAc7j7dzACvk6EDb-320-80.jpg)
Coaxial vs optical vs HDMI: which is the best audio connection to use?
By Andy Madden last updated
You're probably familiar with each audio option, but which should you be using and why? Allow us to explain.
![Speaker cable: QED Golden Anniversary XT](https://cdn.mos.cms.futurecdn.net/Vo98WiejTFpGGn8k26b8x6-320-80.jpg)
QED turns 50 years old and launches the Golden Anniversary XT to celebrate.
Get the What Hi-Fi? Newsletter
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
