Best hi-fi and AV racks 2025: budget and premium models tried and tested
Hi-fi rack: Atacama Elite ECO 24 Reference
(Image credit: What Hi-Fi?)
If you have a serious hi-fi or AV system, you've probably given a fair amount of thought to the cabinets, shelves or dedicated racks to place these products on. Not only are equipment racks necessary for stable support and neatly presenting your kit, but specialist racks are recommended if you care about getting the absolute best out of your sound system.
Some people don't believe racks make much of a difference to the performance of a sound system. We strongly disagree, as hi-fi and/or home cinema electronics, including sensitive products like turntables and CD players, require a stable, level surface and isolation from unwanted vibrations if they are to have the best chance of delivering their full performance potential.
In our experience with testing racks over the last 40+ years, the best hi-fi and AV racks can have a notable effect on the performance of an overall system, simply by minimising the effect of vibrations and mechanical energy on the products themselves.
We have tested all of the options below in our dedicated listening rooms, with the top-recommended racks offering the best combination of stability, build quality and design, as well as elevating a system's audio performance even further.
Written by
Kashfia Kabir
Written by
Kashfia Kabir
I've been reviewing all things hi-fi (amplifiers, CD players, turntables and more) for over a decade, and in that time I've heard what a difference a dedicated rack can make to a system's overall audio performance. Having had a hand in assembling and reviewing all the racks recommended on this page, I am confident that they will suit most people's systems and budgets. We would always recommend checking the dimensions, rack combinations and total weight supported before purchasing, to ensure it's the right option for your kit.
Best hi-fi rack overall
Atacama Evoque Evo 60-40 SE2 rack on a white backgroudn
This Award-winning rack is great for most equipment. (Image credit: Atacama)
1. Atacama Evoque Eco 60-40 SE2
Why you can trust What Hi-Fi? Our expert team reviews products in dedicated test rooms, to help you make the best choice for your budget. Find out more about how we test.
What Hi-Fi? Awards winner. Well-made and Award-winning support for your system.
Specifications
Modular: Yes
Max load per shelf: 30kg
Floor spikes: Yes
Finishes: 3
Dimensions (hwd): 67 x 60 x 40cm
Reasons to buy
Well-made
Modular design
Helps your system reach its potential
Reasons to avoid
Cable management accessories cost extra
If you’re of the opinion all hi-fi racks are created more or less equal, the Evoque Eco 60-40 SE2 will make you rethink your position. It's as fine an equipment support as we’ve tried for the money – and it's the current winner of the Best Equipment Rack at the What Hi-Fi? Awards.
It's well engineered and the bamboo shelving is beautifully finished. Great care has been taken to control the flow of mechanical energy in the rack’s structure, with each leg decoupled from the shelf it's attached to.
Paying just short of £600 for a three-tier Evoque Eco SE2 is hardly a trivial sum, but if you really want to hear just how well your system can perform, this is a sound investment.
Read our full Atacama Evoque Eco 60-40 SE2 review
Best budget hi-fi rack
Hi-Fi Racks Omnium8 on a white background
The Omnium8 is versatile, nicely made and able to deal with pretty heavy loads. (Image credit: Hi-Fi Racks)
A wonderfully versatile hi-fi rack that lets your system sound its natural self.
Specifications
Modular: Yes
Max load per shelf: 90kg
Floor spikes: Yes
Finishes: 8
Shelf dimensions (hwd): 27 x 60 x 40cm
Reasons to buy
Allows for a weighty, natural sound
Impressive versatility
Reasons to avoid
Atacama rival allows for more precision from your system
The Hi-Fi Racks Omnium8 is an incredibly versatile rack. There’s a choice of eight standard finish options and no less than four different types of uprights. Buyers can specify the number of shelves, their spacing and whether the uprights are bolted or spiked. You get the idea – this rack can be configured to accommodate just about any set-up.
And whatever the configuration, this solid oak rack support will add sonic weight and warmth to your kit. The Atacama Evoque Eco 60-40 SE2 (above) might offer a touch more agility and precision, but both set-ups render similar amounts of detail.
A superb, high-quality product. If its looks and flexibility float your boat, dive right in. You won’t be disappointed.
Read our full Hi-Fi Racks Omnium8 review
Best premium hi-fi rack
Handsome looks and study build quality make the ECO 24 Reference a winner. (Image credit: What Hi-Fi?)
Premium hi-fi support that doubles up as beautiful furniture.
Specifications
Modular: Yes
Max load per shelf: 80kg
Floor spikes: Yes
Finishes: 2
Shelf dimensions (wd): 60cm x 40cm
Reasons to buy
Excellent build quality
Attractive, modular design
Allows your kit to perform in a more mature, elevated manner
Cable management panels available
Reasons to avoid
Can add up to be pricey
Optional vinyl storage module is expensive
Atacama's newest and most premium range of racks is a brand new design from the Evoque SE2 (and £100 pricier per shelf), with the brand continuing its use of bamboo material throughout. The Elite Eco 24 features solid bamboo legs and is a more high-quality design that looks rather fetching too.
As ever, the design is modular and now includes cable management panels, which are now handily compatible with other models too. The grooves cut into the underside of each shelf direct vibrations and mechanical resonance away from the kit more efficiently in this model, and the overall effect on our system is one of an open, organised, more dynamic and precise sound. Bass sounds tauter and deeper than when using the same kit placed on the Evoque rack, and there's a sense of ease with more subtleties revealed that elevate the system's overall performance even further.
Yes, each shelf can add up to be rather pricey, but if you have a premium to high-end system, it's worth investing in this sturdy, great-looking specialist support rack that will let your system perform at its full potential.
Read our full Atacama Elite Eco 24 Reference review
Also consider
Blok Stax 2G hi-fi rack
Blok Stax 2G: If you are after a more modern-looking shelf compared to the traditional designs above, the latest collection from Blok is worth considering. Assembly is a breeze, it's thoughtfully put together, and there are a variety of minimalist, lifestyle-friendly finishes. The Stax 2G is modular and you can buy a pre-set collection or additional shelves as needed as your system grows. There is a dedicated "LP" shelf for storage vinyl records, too.
How to choose the best hi-fi and AV racks
For most products and systems, especially if on the budget side, any solid shelf, sideboard or cabinet (as long as it's level and rigid) is perfectly fine. But if the individual components in your system are priced at £1000/$1500 or higher, then we would recommend looking into specialist racks that are designed specifically for minimising the amount of unnecessary resonances and vibrations that could affect how your system performs.
A poor or unstable rack can negatively impact your kit's performance (especially in the case of turntables and CD players) meaning you'll have (potentially) spent all that money only for it to be impaired by something that could easily be fixed. Clever design elements such as spikes, damping gaskets and even the specific materials used in the racks help to eradicate or reduce vibration, allowing each hi-fi component to perform at its best
Most racks are modular, so you can select the number of shelves you need, the height or length of shelf required, and build your rack around your system. They're usually flat-pack but easy to assemble in around 15 minutes or so in our experience. You'll also want to pay attention to the type of wood used to make the shelves, or glass if you prefer, and choose a finish that suits your listening room's style.
How we test hi-fi and AV racks
We have state-of-the-art, acoustically treated testing facilities where our team of experienced, in-house reviewers test the majority of hi-fi and AV kit that passes through our door – including equipment racks.
What Hi-Fi? is all about comparative testing, so we build and compare every equipment rack we review against each other and the current leader in its field, to gauge how it compares to the best-in-class competition. We keep What Hi-Fi? Award winners – such as the long-standing Atacama Evoque Eco 60-40 SE2 – in our stockrooms so we can always pit new products against ones we know and love, and we do our best to review as many new models in as many markets as possible to ensure our contextual knowledge is the best it can be.
We are always impartial in our testing and ensure we take time to build and set up hi-fi and AV racks properly and securely. We use a variety of products – such as CD players, turntables and amplifiers – to place on the rack to see how well it copes with different sizes and types of products, as well as the impact the rack's materials and design have on the full system's overall performance.
All review verdicts are agreed upon by the team as a whole rather than an individual reviewer to eliminate any personal preference and to make sure we're being as thorough as possible. There's no input from PR companies or our sales team when it comes to the verdict, with What Hi-Fi? proud of having delivered honest, unbiased reviews for decades.
You can read more about how we test and review products on What Hi-Fi? here.
MORE:
Check out the best stereo amplifiers across all budgets
8 ways to make your hi-fi sound better for free
Best hi-fi systems: micro, vinyl and streaming music systems for the home
What Hi-Fi?
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
Read more about how we test
Read more
Best speaker stands: budget and premium
Best speaker stands 2025: budget and premium models tested
Rega Planar 3 RS Edition turntable
Best turntables 2025: top record players tested by our expert reviewers
The Revo SuperConnect Stereo on a tabletop next to plants
Best hi-fi systems 2025: CD, vinyl and streaming music players for the home
speakers, amplifier and turntable on a grey background
This terrific, traditional vinyl system celebrates the best of British hi-fi
Wharfedale Evo 4.4 towers flanking a wall-mounted TV
Best floorstanding speakers 2025: all models tested by experienced reviewers
A turntable, amplifier and a pair of floorstanding speakers against a grey background
Technics leads a talented and versatile vinyl system that will excel in larger rooms
Latest in Hi-Fi
Gryphon Audio Diablo 333 integrated amplifier
The Clearaudio Diamond Jubilee MC cartridge on a bed of diamonds.
This moving coil cartridge costs as much as a family hatchback
Musical Fidelity M8x DAC
Music Fidelity's high-end M8x DAC wants to "transform digital signals into breathtaking analogue sound"
Rotel DX-3 DAC/headphone amp
Rotel's do-it-all DAC/headphone amp wants to be your "ultimate desktop audio companion"
Bang & Olufsen Beogram 4000c
Bang & Olufsen has given its iconic Beogram 4000 Series turntable a stylish rebirth – but good luck getting one!
WiiM Ultra music streamer
WiiM's ultra-versatile and affordable digital hub gets a prime spot in our best music streamers buying guide
Latest in Best Buys
Sony WF-C510 in-ear headphones
Best cheap wireless headphones 2025, tested by our experts
Bose QuietComfort Ultra Headphones and AirPods
Best travel headphones: our experts pick the best pairs for your next trip
TCL 85C805K 4K TV
Best Mini LED TV: 5 super bright options recommended by our experts
The Sony Bravia Theatre Bar 9 soundbar photographed in front of the Bravia 9 TV
Best Sony soundbars 2025: these are the 5 our reviewers recommend
A person holding a smartphone in front of a laptop. The smartphone displays that a VPN is switched on
Best VPN service 2025
Apple AirPods Max, AirPods Pro 2 and AirPods 3 in a row on desk with records
Best AirPods 2025: Apple's wireless headphones ranked and rated
