IFA 2014: Onkyo unveils high-res streaming CD player and micro systems
Onkyo has announced the launch of the C-N7050, described as its first-ever hi-fi source that brings together CD playback and high-res music streaming from media servers, PCs and mobiles. Also new are two Colibrino mini systems.
The C-N7050 network player has been constructed around an anti-vibration metal chassis, uses a floating 32-bit digital signal processing engine and TI Burr-Brown's high-end PCM1795 32-bit digital-to-analogue converter.
Native DSD and 192kHz/24-bit FLAC files are supported by Onkyo's new device, along with other high-res, lossless and compressed formats. DLNA technology is on board, too, which allows you to stream and control music from a mobile device.
MORE: High-resolution audio - everything you need to know
Onkyo's Vector Linear Shaping Circuitry (VLSC) has also been used to remove "high-frequency pulse noise from digital recordings", which the firm says is designed to deliver a cleaner and more natural sound.
Internet radio comes courtesy of the vTuner internet radio service and there's a USB port on the front panel allowing direct-digital connections between the C-N7050 and Apple devices.
Other compatible devices can be connected using either the front or rear USB ports, while you'll also find optical and coaxial outputs; analogue output terminals; and RI compatibility for integrated control of other components.
MORE: Read all our Onkyo reviews and news
Get the What Hi-Fi? Newsletter
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
CS-265 and CS265DAB Colibrino mini systems
Onkyo has also unveiled the new CS-265 and CS-265DAB Colibrino CD mini systems, which sport wireless Bluetooth and NFC technology alongside a host of typical all-in-one system features.
The firm has increased power by 25 per cent to the latest additions to the Colibrino range, which now offers 20 watts per channel at 6ohms. A full digital processing system and digital amplifier can also be found on board.
Each of the two-way bookshelf speakers comes with a 10cm cone woofer and 2cm balanced dome tweeter, while a direct-digital USB connection lets you connect your Apple device – either via lightning or legacy 32-pin Apple connection.
A new disc-reading mechanism has been deployed to reduce CD load times and both systems offer MP3 playback from USB devices. Unsurprisingly, the CS-265DAB indicates that it has a DAB+ tuner with 40-present memory.
Pete was content editor on What Hi-Fi?, overseeing production and publication of digital content. In creating and curating feature articles for web and print consumption, he provided digital and editorial expertise and support to help reposition What Hi-Fi? as a ‘digital-first’ title; reflecting the contemporary media trends. He is now a senior content strategist.
