Best subwoofers 2025: brilliant bass for music and movies
Wireless subwoofer: Sonos Sub
(Image credit: Sonos)
If your superhero films sound a little less than super, or your hi-fi is sounding a little lean, adding or upgrading a subwoofer is a great way of beefing up the bottom-end performance of any two- or multi-channel system.
A good subwoofer provides enough bass depth and weight to shake your sofa during those crucial movie moments, but it also needs to be tight and tuneful to make sure that the entire soundtrack is accurately and engagingly reproduced in your living room. A bad one will just drown out all the other frequencies with its bassy sludge and make your movies and music sound worse.
Unlike a lot of product categories that we cover at What Hi-Fi?, subwoofers are additions to your system rather than being products that can function independently of others – nobody’s going to watch a movie or listen to an album through a subwoofer alone.
That can make choosing one particularly tough, so we’ve created this list of the top-performing subwoofers from our exhaustive reviews back catalogue. Every sub below has been through our rigorous testing process, so you can be sure it’s worth your hard-earned cash.
Read on for our pick of the best subwoofers for stereo and surround sound systems, and check out the best speaker packages you can buy if you're looking to create the best home cinema system too.
Recent updates
February 2025: checked pricing, and availability of the entries and removed the Sonos Sub Mini from the list.
The quick list
Tom Parsons
Tom Parsons
I am What Hi-Fi?’s TV and AV Editor but even in my spare time there’s nothing I like more than closing the curtains, putting on a movie and cranking up my home cinema system, so I know exactly how important a good subwoofer is to that experience. Nothing gives a film that cinematic feeling like a good dollop of low-end on the soundtrack, but not being able to make out dialogue is one of my movie pet hates. I’ve got first-hand experience with all of these subwoofers, and none of them would be here if they couldn’t get that all-important balance right.
Best subwoofer overall
Why you can trust What Hi-Fi? Our expert team reviews products in dedicated test rooms, to help you make the best choice for your budget. Find out more about how we test.
A black B&W ASW610 subwoofer on a white background
Incredible amounts of power and dynamism from this deceptively compact subwoofer. (Image credit: B&W)
The B&W ASW610 sounds bigger than it looks and more expensive than its price-tag.
Specifications
Dimensions (hwd): 31 x 31 x 35 cm
Drivers: 250mm (10in) paper / Aramid fibre cone long-throw
Power output: 200 watts
Weight: 12.5kg
Reasons to buy
Well-extended bass for its size
Good finish
Small and well-equipped
Reasons to avoid
Nothing of note
Don’t be fooled by the diminutive form of B&W’s ASW610; this is the subwoofer we would recommend over all others if you want to give your surround-sound system a boost at the bottom end.
Despite measuring just 31cm tall, the ASW610 is capable of formidable power, its 200W amplifier controlling the excursions of its 25cm Kevlar/paper drive unit in impressive style. There's depth, drive and authority to belie its size, with a brilliant blend of power and musicality.
Available in either black or white, its compact dimensions make it easy to accommodate in all but the smallest living spaces, but it also has the necessary dynamism to fill rooms of all sizes with sound.
Whether it’s a movie soundtrack or one of your favourite albums, the ASW610 can deliver bass with subtlety and speed, making it a gen uine all-rounder when it comes to delivering solid bass as part of a hi-fi or home cinema system.
Read our full B&W ASW610 review
Best budget subwoofer
Best subwoofers: Q Acoustics QB12
A terrific subwoofer that balances punch and precision. (Image credit: Future)
Upgrade your 3000i or Concept 5.1 package.
Specifications
Dimensions (hwd): 40 x 40 x 45 cm
Drivers: 1x 300mm (12in) Paper-Kevlar, Aluminum cone long-throw
Power output: 400 watts
Weight: 21.5kg
Reasons to buy
Punchy and powerful
Doesn’t impose sonically
Well integrated
Reasons to avoid
Not easily accommodated
Q Acoustics’ QB12 might be the most wallet-friendly choice on our list here, but it could end up costing you in other ways, such is the sheer power that lies within its hefty frame.
The QB12 smashes through the action like a steam train, hitting you right in the stomach and taking your whole body along with it, so you might want to warn your neighbours when it’s movie night (or move to a bigger house).
That’s hardly surprising considering its 12in driver is pushed by 220 watts of Class D amplification, but there’s much more to it than just brute force; the QB12 is also precise, detailed and really rather dynamic.
It’s designed to work best with Q Acoustics’ 3000i suite, as well as the Concept 5.1 speaker range, but as long as what you pair it with has enough oomph to integrate effectively without being overwhelmed, and you have the physical space to accommodate it, the QB12 is a brilliantly affordable way to upgrade the low-end response in your home-cinema set-up. Next door’s peace and quiet be damned.
Read our full Q Acoustics QB12 review
Best subwoofer for Sonos
A black Sonos Sub on a white background
An effective way to boost your Sonos multi-room system's sound. (Image credit: Sonos)
This slim, wireless subwoofer is a solid addition to a Sonos music or cinema system.
Specifications
Dimensions (hwd): 39 x 40 x 16 cm
Drivers: 2 x powered drivers
Power output: n/a
Weight: 16kg
Reasons to buy
Versatile placement
Simple set-up
Integrates well
Reasons to avoid
A little expensive
Not the punchiest
Sonos started out fully focused on multi-room hi-fi kit, but the launch of the original Sonos Sub back in 2012 showed that the company cared about home cinema sound, too.
The eye-catching contemporary design sets it apart as something a little bit different to the other, more traditional subwoofers further up this page. Apart from the power cable it’s entirely wireless (although you can connect it to your router with an ethernet cable if the Wi-Fi isn’t up to scratch). You can use the Sub to create a multi-channel system with one of Sonos’ soundbars and, if you can afford it, some of its other wireless speakers such as the Era 300.
The Sonos Sub is big and heavy but you can lay it down flat if that will help you to find a home for it. Similar sonic characteristics ensure the Sub integrates well with the company's other wireless speakers, and the extra weight, power and scale is obvious.
It’s not cheap, and when playing music bass lines can be a little on the fat side, but its easy setup and unique characteristics make it a fine addition to any movie-loving Sonos fan’s setup.
Read our full Sonos Sub review
How to choose the best subwoofer for you
Adding a subwoofer to your home cinema setup is essentially the same as buying a new piece of furniture for your living room, so it requires a bit of forward planning. You wouldn’t buy a five-seater sofa and only work out where to put it once it arrived, would you?
Fortunately none of the subwoofers on our list above are quite that large, but they all require about a foot of room around them, so measure your space and bear that in mind when making a decision. Even more fortunately, from a sonic point of view subwoofers aren’t too fussy about placement, so at least you don’t have to worry about positioning it directly underneath the TV.
Size isn’t just a physical consideration when it comes to choosing a subwoofer either. Larger subs tend to be more powerful, with higher RMS figures, so make sure everything is in proportion. Too much power in a small room runs the risk of overwhelming the space, plus the proximity of your neighbours means you’re unlikely to make the most of it anyway (unless you really don’t like them).
Most subwoofers will require a direct wired connection to your AV receiver, so that’s also something to bear in mind when choosing one. If running cables around your living room is going to prove problematic you can also get wireless subs that only need a power cable to function, but bear in mind that a lot of them only work within a specific closed ecosystem (the two Sonos ones above are a good example).
Fundamentally, a subwoofer is always going to be an addition to your setup rather than a standalone item, so making sure it fits with what you’ve already got – and the room you’re using it in – is key.
How we test subwoofers
A lot of products we test at What Hi-Fi? can be evaluated almost in isolation. Things like TVs and headphones need sources, but they’re entirely responsible for their own performance. Subwoofers, however, are only ever additions to other speakers, which makes reviewing them a slightly unusual proposition.
Every subwoofer we test is given the same treatment. In our state-of-the-art facilities we will pair them with a suitable set of reference speakers as part of a surround-sound package. After ensuring they are set up correctly, we will test each subwoofer in different positions in the room and with a range of different films and musical genres.
A key element of the What Hi-Fi? review process is comparative testing, so we will also bring in a rival subwoofer at a comparable price (and often cheaper and more expensive alternatives, too) to see how they stack up.
No matter what we’re reviewing, all of our verdicts are agreed upon by the team as a whole rather than a single reviewer, helping to ensure consistency and avoid individual subjectivity. The What Hi-Fi? team has more than 100 years collective experience of reviewing, testing and writing about consumer electronics – and that includes subwoofers – so our opinion is trusted by retailers and manufacturers, as well as consumers, the world over.
From all of our reviews, we only choose the top subwoofers to feature in this Best Buy. That's why if you take the plunge and buy one of the products recommended here, or on any other Best Buy page, you can rest assured you're getting a What Hi-Fi?-approved product.
You can read more about how we test and review products on What Hi-Fi? here.
MORE:
FAQ
Where should I place my subwoofer?
Bass isn’t as directional as the frequencies further up the range, so the good news is you have significantly more freedom over where you place your subwoofer than you do with your other speakers. That being said, the acoustics of your room will have an impact on the sub’s performance, so it’s worth trying a few positions to find the one that provides the best balance of sound quality and convenience. For more in-depth tips, read our guide on how to set up your subwoofer.
Can I use a Sonos sub with a non-Sonos soundbar or speakers?
There’s a very short answer to this question: no. The longer answer is that Sonos products work on their own proprietary network, so without a Sonos soundbar, or at least one of the company’s other Wi-Fi speakers, the Sonos Sub and Sub Mini are just very large paperweights.
What’s the difference between a sealed and ported subwoofer?
Unless you’re trying to fill a very large room with bass you don’t need to consider a ported subwoofer, and there are none on the list above anyway, but it’s still worth knowing the difference. The cabinet on a sealed sub is, you guessed it, fully sealed, which helps to control the sound the woofer makes. A tuned port (or ports) in the cabinet generates extra output below what the drive unit itself is capable of, but they tend to be bigger and more expensive than sealed subs. For home listening, a sealed subwoofer should be plenty powerful enough.
Tom Parsons
Tom Parsons has been writing about TV, AV and hi-fi products (not to mention plenty of other 'gadgets' and even cars) for over 15 years. He began his career as What Hi-Fi?'s Staff Writer and is now the TV and AV Editor. In between, he worked as Reviews Editor and then Deputy Editor at Stuff, and over the years has had his work featured in publications such as T3, The Telegraph and Louder. He's also appeared on BBC News, BBC World Service, BBC Radio 4 and Sky Swipe. In his spare time Tom is a runner and gamer.
With contributions from
Read more
Q Acoustics' three Q SUB models side by side against a brown backdrop
Trio of new Q SUB subwoofers bring bass boosts for Q Acoustics' multi-Award-winning speakers
Wharfedale Diamond 12.3 speaker package grouped together against a grey background
Best surround sound systems 2025: home cinema speakers and soundbars put to the test
Best soundbases: the best budget TV speakers for under your TV
Subwoofer: Sonos Sub Mini
Sonos Sub Mini
Sonos Arc Ultra soundbar
Best Dolby Atmos soundbars 2025: our reviewers' 5 recommendations
Best soundbars 2025: options for every need, recommended by our experts
Latest in Subwoofers
The McIntosh PS1K powered subwoofer in a modern minimalist room with wood panelling
McIntosh's new powered subwoofer promises ground-shaking bass at a wallet-trembling price
Nakamichi Dragon soundbar and subwoofer in a home cinema system
Nakamichi unleashes a rib-shaking 12-inch subwoofer upgrade for its Dragon home cinema system
Klipsch Flexus soundbar, subwoofer and speaker in a modern living room with a big wall mounted TV and white media unit
9 of the best action scenes to test your subwoofer
KEF KC92 in a living room next to floorstanding speakers.
KEF announces five new subwoofers to suit a range of rooms and budgets
PSB SubSeries BP8 lifestyle image next to a sofa
PSB's high-performance subwoofer wants to eliminate low-end resonance from your listening
Latest in Best Buys
Sony WF-C510 in-ear headphones
Best cheap wireless headphones 2025, tested by our experts
Bose QuietComfort Ultra Headphones and AirPods
Best travel headphones: our experts pick the best pairs for your next trip
TCL 85C805K 4K TV
Best Mini LED TV: 5 super bright options recommended by our experts
The Sony Bravia Theatre Bar 9 soundbar photographed in front of the Bravia 9 TV
Best Sony soundbars 2025: these are the 5 our reviewers recommend
A person holding a smartphone in front of a laptop. The smartphone displays that a VPN is switched on
Best VPN service 2025
Apple AirPods Max, AirPods Pro 2 and AirPods 3 in a row on desk with records
Best AirPods 2025: Apple's wireless headphones ranked and rated
  • Deswizard
    You've been with this company for ten years and this is the best you could do? Three mediocre subs and quit? I'm disappointed.
    Reply
